| Author |
MarkRD Occasional Visitor
Joined: 16/01/2003 20:56:43 Posts: 20 Location: Wales
Posted: Sun Sep 14, 2003 8:04 am Post subject: TTN2 Post your fault here!!! |
Ipaq 3870
128Mb SD Card for GB map
Garmin GPSII+
No problems so far _________________ Mark |
| Back to top |
RichDem Frequent Visitor
Joined: 12/12/2002 11:57:47 Posts: 259 Location: East Yorkshire
Compaq Ipaq 3950 (ROM 1.00)
Leadtek 9532
No longer able to use the "Alternatives & Navigate to" options. Nothing happens when these are selected
Richard |
| Back to top |
RobMob Regular Visitor
Compaq 3970
Emtac BT GPS
128MB SD card
ROM 2.0
Few immediate findings after my SD card format and map re-install.
1) Whilst able to now set up favourites (by the way I inadvertantly did not copy over favourites file to SD card and have therefore started from scratch)when trying to navigate to them rather than hang program now closes. But just discovered only does this when a route is already in place. If I clear the existing route first in Map view I can then navigate successfully to favourites. Didn't have this problem in TTNAV1.
2) Selecting Alternative route or Original Route in Map screen - program closes
3) Sometimes able to get Instructions other times TTNAV2 closes.
RobMob |
| Back to top |
Houmark Occasional Visitor
Joined: 09/04/2003 23:43:16 Posts: 4 Location: Denmark
HP IPAQ 5450
Socketcom / Emtac BT GPS
Program installed in internal memory
Maps installed on 256 MB Sandisk Ultra Compact Flash Card
No problems registred. |
| Back to top |
boblister Pocket GPS Verifier
Joined: 01/04/2003 17:49:45 Posts: 108 Location: Ulverston, Cumbria
HP Ipaq 3970
Sapphire RGM-2000 also Garmin GPSIII+
Maps on a Sandisk 128K CF |
| Back to top |
Tony_B Occasional Visitor
Joined: 01/11/2002 13:37:04 Posts: 19 Location: United Kingdom
iPAQ 3870 64MB MMC
Hiacomm Hi-203
No problems except 64MB map will not fit on a 64MB card MMC or CF |
| Back to top |
agibbs Occasional Visitor
Joined: 11/02/2003 09:32:19 Posts: 24 Location: United Kingdom
Pocket Loox
Holux GM-270 CF
TT2 internal, maps on SD card (no special formatting)
Problems with system freezes, especially setting depart/dest from favourites _________________ Andrew Gibbs |
| Back to top |
NickR Occasional Visitor
Joined: 05/03/2003 12:50:49 Posts: 42 Location: United Kingdom
iPAQ 3970 (ROM 2.10)
iPAQ Nav System
maps on 256mb CF card in iPAQ Nav System Sleeve
Problems with system freezes and program crashes, especially setting depart/dest from favourites. Also did not close GPS program but does now when closing task TOMTOM 2 ??????
Nick
| Back to top |
Stealie Occasional Visitor
Joined: 17/11/2002 22:26:02 Posts: 8 Location: United Kingdom
Compaq Ipaq 3950 (ROM 1.10)
Leadtek 9532
Unable to navigate from favourites with tap & hold feature, problems navigating to any favourites especially "Home"
Steve |
| Back to top |
SteveRose Occasional Visitor
Joined: 07/01/2003 13:18:40 Posts: 18 Location: United Kingdom
Compaq iPAQ 3870 with 128 SD card
Leadtek 9531
No problems found |
| Back to top |
rwbthatisme Occasional Visitor
Joined: 20/09/2002 21:07:35 Posts: 55 Location: United Kingdom
Ipaq 5455
Navman 3000
Sandisk 256mb CF
no problems _________________ wibble |
| Back to top |
oisky Regular Visitor
Joined: 18/02/2003 15:38:44 Posts: 112 Location: United Kingdom
iPAQ 5450
Standard TomTom Reciever
Sandisk 128 mb SD card
Freezes when navigating to HOME or in favourites navigating to HOME. Interestingly doesn't crash if I change my home address to another 'known' good address? Maybe some areas in Britain are 'faulty' when navigating to ??? |
| Back to top |
clem Regular Visitor
Joined: 15/10/2002 20:16:43 Posts: 86 Location: United Kingdom
Oisky,
I get the same problem. If you use the recent destination list instead of home it works fine (as long as your home destination is in the recent destination list of course). it's a workaround but it does the trick until TT release the update. |
| Back to top |
steve111 Occasional Visitor
Joined: 06/02/2003 20:09:59 Posts: 24 Location: United Kingdom
Ipaq 3970 (ver 2.00)
ematac bluetooth gps
maps on SD card
problems:
1/ often can not get gps signal to respond.
2/ 3D postion jumps about, totally unuseable in 3D mode also no speed indication.
3/ very slow operation of address finding
steve |
| Back to top |
Michael Occasional Visitor
Joined: 11/02/2003 18:24:23 Posts: 31 Location: United Kingdom
Compaq iPAQ 3630
Haicom H-203E
GPS Assist
TTN2 & GPSAssist on internal RAM, GB Map on Toshiba 2GB PCCard.
Seems to be fine in the majority, but experience frequent long pauses while in navigation mode.
Michael |
| Back to top |
| Back to top |
