| Author |
Dave Frequent Visitor
Posted: Sun Feb 13, 2005 8:05 pm Post subject: REVIEW COMMENTS: TomTom Nav BT Installation for Smarties |
Many of you asked for an "idiot's guide to the TomTom Navigator installation for BT receivers when you want to run other programs, too", so now you have one. But it's not actually an idiot's guide, rather a smart way to work around TomTom's attempt at World Domination - therefore we call this a Smarties guide.
Lutz has created full step-by-step instructions which is available here. |
| Back to top |
emjaiuk Frequent Visitor
Joined: Dec 06, 2003 Posts: 335 Location: North Surrey (TW17) UK
Posted: Sun Feb 13, 2005 8:47 pm Post subject: |
Brilliant! I for one have been waiting for this. I've always eventually ended up being able to use both TT and in my case MM, but only after extensive trial and (mostly) error. One query though, I was under the impression that BTGPS 2.07 (my current version) was ok. Is this not now the case. Is it worth uninstalling 2.07 and installing 2.06?
Malcolm _________________ Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home |
| Back to top |
lbendlin Pocket GPS Staff
Posted: Sun Feb 13, 2005 8:52 pm Post subject: |
If you have a working setup then don't touch anything.
But strictly speaking yes, version 2.07 turned out to have the same issues on some machines, so if you want to be absolutely sure you should go back to version 2.06 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
| Back to top |
xda Lifetime Member
Posted: Mon Feb 14, 2005 9:54 am Post subject: |
Lutz, in your guide you mention removing TomTom~GPS from remove programs once then soft reset and it re-appears.
Just tried that on my XDA2 with GPS 3.07 and it didn't remain after a reset. Is this because 3.07 is behaving correctly and not hijacking the BT stack? _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
| Back to top |
johnwx Lifetime Member
Posted: Mon Feb 14, 2005 3:01 pm Post subject: |
Using XDA2i follow the article ok but after 1st removal confirm ok but it does not give the option to reinstall original so now left without BT.
2003SE |
| Back to top |
Posted: Mon Feb 14, 2005 6:32 pm Post subject: |
You may already have done one "uninstall" earlier.
If you have a working setup where both TomTom and other programs can access the GPS receiver then you should not change that.
If you did the uninstall and now the GPS driver is completely gone then simply re-install it either from the CD or from our downloads link.
(And then you can do the uninstall again ;-) ) _________________ Lutz
| Back to top |
Posted: Tue Feb 15, 2005 1:29 am Post subject: |
Sorry seemed to have confused you by being too brief.
Have XDA2i running win 2003SE, tomtom 3.01.
I can get bluetooth headset profile to work before installing tomtom, however after installing the dreaded tomtom the headset profile does not work.
The BT GPS does, so 50% there!
I follow your instructions and remove tomtom GPS, it removes ok I do not then get the message to reset pocket pc.
The headset does not work.
If I then install 2.06 the headset does not work.
is there a CAB file for just 3.01.
Or how else can I keep both BT working?
John |
| Back to top |
Posted: Tue Feb 15, 2005 2:39 am Post subject: |
You may have to go the long route - complete re-install of the PocketPC, Install of TomTom Navigator 3.07 via CAB file, install of TT GPSD 2.06 via CAB file. That's the only way you can make sure your BT stack is not messed around with. _________________ Lutz
| Back to top |
xda Lifetime Member
Posted: Tue Feb 15, 2005 2:55 am Post subject: |
| lbendlin wrote: | You may already have done one "uninstall" earlier.
(And then you can do the uninstall again ;-) ) |
Just re-installed 3.07
Then remove Program TomTom~GPS selected, remove.
Soft Reset.
Start, Settings, System. No GPS Icon
Start, Settings, System, Remove Programs. No TomTom~GPS _________________ Graham.
| Back to top |
Posted: Tue Feb 15, 2005 2:59 am Post subject: |
They must have changed the procedure then - I tested with 3.03 and it still needed two uninstalls.
Or maybe it is machine specific.
Anyhow - if you now install GPS 2.06 then you should be able to use both TomTom and other GPS programs. _________________ Lutz
| Back to top |
DavidW Pocket GPS Moderator
Posted: Tue Feb 15, 2005 4:52 am Post subject: |
GPS 3.07 doesn't hook into the Bluetooth stack on all machines, Lutz. For example, it doesn't seem to hook in on anything using the Broadcom 1.5.0, such as the latest iPAQs. It definitely doesn't hook into the Bluetooth stack on my hx4700.
The advice should be to do a single uninstall only if third party software can't access a Bluetooth GPS. If TomTom GPS hasn't hooked into the Bluetooth stack, a single uninstall removes TomTom GPS from the machine (solution: reinstall GPS 3.07!).
David |
| Back to top |
xda Lifetime Member
Posted: Tue Feb 15, 2005 9:24 am Post subject: |
Thanks for that David, Lutz must have thought I was taking the ..
So XDA2 with the latest Rom doesn't get its BT stack hijacked by TomTom. _________________ Graham.
| Back to top |
Posted: Wed Feb 16, 2005 11:35 am Post subject: |
Thanks for the advice.
Istalled 3.07 via cab
installed 2.6 gps
installed voice
installed maps
All works fine able to use BT on clip-on GPS, and BT headset Jabra 250.
All on o2 XDA2i :D |
| Back to top |
alix776 Pocket GPS Moderator
Posted: Sat Feb 19, 2005 8:27 pm Post subject: |
sorry guys it does hijack the bt stack on the xda2 i tried this friday (long unload) and put copilot on the xda 2 couldnt find my tt gps so did the single un install no luck ttgps will not work so maybe it procedure for teh xda2 needs to be different for the xda as the bt manager is very limited in what you can do in it.  _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
| Back to top |
Posted: Sat Feb 19, 2005 10:00 pm Post subject: |
for the xda 2 install bluetooth tools delete and repair the receiver then install gps 2.06 make sure you remove 2.07 or above then soft reset and you should be able to use other programs on the xda2 with tt installed _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
| Back to top |
| Back to top |
