Pocket GPS World :: View topic - REVIEW COMMENTS: TomTom Nav BT Installation for Smarties
Goto page 1, 2, 3  Next
PostPosted: Sun Feb 13, 2005 8:05 pm    Post subject: REVIEW COMMENTS: TomTom Nav BT Installation for Smarties Reply with quote
Many of you asked for an "idiot's guide to the TomTom Navigator installation for BT receivers when you want to run other programs, too", so now you have one. But it's not actually an idiot's guide, rather a smart way to work around TomTom's attempt at World Domination - therefore we call this a Smarties guide.
Lutz has created full step-by-step instructions which is available here.
emjaiuk
PostPosted: Sun Feb 13, 2005 8:47 pm    Post subject: Reply with quote
Brilliant! I for one have been waiting for this. I've always eventually ended up being able to use both TT and in my case MM, but only after extensive trial and (mostly) error. One query though, I was under the impression that BTGPS 2.07 (my current version) was ok. Is this not now the case. Is it worth uninstalling 2.07 and installing 2.06?
Malcolm
Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home
PostPosted: Sun Feb 13, 2005 8:52 pm    Post subject: Reply with quote
If you have a working setup then don't touch anything.
But strictly speaking yes, version 2.07 turned out to have the same issues on some machines, so if you want to be absolutely sure you should go back to version 2.06
xda
PostPosted: Mon Feb 14, 2005 9:54 am    Post subject: Reply with quote
Lutz, in your guide you mention removing TomTom~GPS from remove programs once then soft reset and it re-appears.
Just tried that on my XDA2 with GPS 3.07 and it didn't remain after a reset. Is this because 3.07 is behaving correctly and not hijacking the BT stack?
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
johnwx
PostPosted: Mon Feb 14, 2005 3:01 pm    Post subject: Reply with quote
Using XDA2i follow the article ok but after 1st removal confirm ok but it does not give the option to reinstall original so now left without BT.
2003SE
PostPosted: Mon Feb 14, 2005 6:32 pm    Post subject: Reply with quote
You may already have done one "uninstall" earlier.
If you have a working setup where both TomTom and other programs can access the GPS receiver then you should not change that.
If you did the uninstall and now the GPS driver is completely gone then simply re-install it either from the CD or from our downloads link.
(And then you can do the uninstall again ;-) )
johnwx
PostPosted: Tue Feb 15, 2005 1:29 am    Post subject: Reply with quote
Sorry seemed to have confused you by being too brief.
Have XDA2i running win 2003SE, tomtom 3.01.
I can get bluetooth headset profile to work before installing tomtom, however after installing the dreaded tomtom the headset profile does not work.
The BT GPS does, so 50% there!
I follow your instructions and remove tomtom GPS, it removes ok I do not then get the message to reset pocket pc.
The headset does not work.
If I then install 2.06 the headset does not work.
is there a CAB file for just 3.01.
Or how else can I keep both BT working?
John
PostPosted: Tue Feb 15, 2005 2:39 am    Post subject: Reply with quote
You may have to go the long route - complete re-install of the PocketPC, Install of TomTom Navigator 3.07 via CAB file, install of TT GPSD 2.06 via CAB file. That's the only way you can make sure your BT stack is not messed around with.
xda
PostPosted: Tue Feb 15, 2005 2:55 am    Post subject: Reply with quote
Just re-installed 3.07
Then remove Program TomTom~GPS selected, remove.
Soft Reset.
Start, Settings, System. No GPS Icon
Start, Settings, System, Remove Programs. No TomTom~GPS
Graham.
Nokia 925 Windows 8
PostPosted: Tue Feb 15, 2005 2:59 am    Post subject: Reply with quote
They must have changed the procedure then - I tested with 3.03 and it still needed two uninstalls.
Or maybe it is machine specific.
Anyhow - if you now install GPS 2.06 then you should be able to use both TomTom and other GPS programs.
DavidW
PostPosted: Tue Feb 15, 2005 4:52 am    Post subject: Reply with quote
GPS 3.07 doesn't hook into the Bluetooth stack on all machines, Lutz. For example, it doesn't seem to hook in on anything using the Broadcom 1.5.0, such as the latest iPAQs. It definitely doesn't hook into the Bluetooth stack on my hx4700.
The advice should be to do a single uninstall only if third party software can't access a Bluetooth GPS. If TomTom GPS hasn't hooked into the Bluetooth stack, a single uninstall removes TomTom GPS from the machine (solution: reinstall GPS 3.07!).
xda
PostPosted: Tue Feb 15, 2005 9:24 am    Post subject: Reply with quote
Thanks for that David, Lutz must have thought I was taking the ..
So XDA2 with the latest Rom doesn't get its BT stack hijacked by TomTom.
Graham.
Nokia 925 Windows 8
johnwx
PostPosted: Wed Feb 16, 2005 11:35 am    Post subject: Reply with quote
Thanks for the advice.
Istalled 3.07 via cab
installed 2.6 gps
installed voice
installed maps
All works fine able to use BT on clip-on GPS, and BT headset Jabra 250.
All on o2 XDA2i :D
alix776
PostPosted: Sat Feb 19, 2005 8:27 pm    Post subject: Reply with quote
sorry guys it does hijack the bt stack on the xda2 i tried this friday (long unload) and put copilot on the xda 2 couldnt find my tt gps so did the single un install no luck ttgps will not work so maybe it procedure for teh xda2 needs to be different for the xda as the bt manager is very limited in what you can do in it. Confused
device Lumia 950 xl
alix776
PostPosted: Sat Feb 19, 2005 10:00 pm    Post subject: Reply with quote
for the xda 2 install bluetooth tools delete and repair the receiver then install gps 2.06 make sure you remove 2.07 or above then soft reset and you should be able to use other programs on the xda2 with tt installed
device Lumia 950 xl
Page 1 of 3
24.034 (25 Mar 26)
