| Author |
JChew Occasional Visitor
Posted: Tue Nov 23, 2004 6:45 am Post subject: Track Recording Function |
| Can anyone please advise how to use the "Track Recording" function under >Settings>Routing? What do I do with the log file that is generated? |
| Back to top |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue Nov 23, 2004 11:07 am Post subject: |
In V2, you could use Oldie's Log Converter programme, available from here and then import the track into, say, Autoroute. This would then give you a breadcrumb trail of your movements. Hopefully, Navman haven't altered the format in V3, and if they haven't it should still work. Note that the data log is saved to the SD card, so make sure you have enough room.
You could also play back the log from within SmartST. _________________ Tim |
| Back to top |
uffe73 Frequent Visitor
Posted: Wed Feb 16, 2005 4:17 pm Post subject: |
| Tim Buxton wrote: |
...You could also play back the log from within SmartST. |
This function never worked for me in SmartST V2. Haven't tried it with SmartST V3 yet, but I will. Can anyone confirm that the recording and playback of log files work with the V3 SW? It could be a useful feature sometimes. _________________ TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70) |
| Back to top |
Posted: Wed Feb 16, 2005 4:26 pm Post subject: |
| Tim Buxton wrote: | | In V2, you could use Oldie's Log Converter programme, available from here and then import the track into, say, Autoroute. This would then give you a breadcrumb trail of your movements. Hopefully, Navman haven't altered the format in V3, and if they haven't it should still work. Note that the data log is saved to the SD card, so make sure you have enough room. |
Tim,
I installed the Log Converter application but realised that it only supports the TomTom log format (.pgl extension). SmartST outputs log files with the extension .gps. Have you actually tried using the tool with Navman log files?
/Ulf _________________ TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
| Back to top |
Posted: Wed Feb 16, 2005 4:37 pm Post subject: |
| uffe73 wrote: | | Tim Buxton wrote: | | In V2, you could use Oldie's Log Converter programme, available from here and then import the track into, say, Autoroute. This would then give you a breadcrumb trail of your movements. Hopefully, Navman haven't altered the format in V3, and if they haven't it should still work. Note that the data log is saved to the SD card, so make sure you have enough room. |
Tim,
/Ulf |
After looking at Oldies webb page I realised that there's a newer version (version 2.02) of the program available that supports .gps log files. Maybe the new version could be added to the download section of this site too.
| Back to top |
Posted: Wed Feb 16, 2005 5:44 pm Post subject: |
Sorry Ulf,
I didn't realise that the Log Converter programme hosted here wasn't the latest one. I have V2.01, which Oldie wrote to include the .gps format of Navman logs after I sent him one of my Navman logs. He then sent me the programme. _________________ Tim |
| Back to top |
Posted: Thu Feb 17, 2005 8:55 am Post subject: |
No probs. I just sent a message to Oldie asking him to upload version 2.02 of the application to the Download section of Pocket GPS World.
Tim, have you tried playing back a recorded log file in SmartST V3? As I said yesterday, this never worked for me in SmartST V2. Nothing happened when I pressed "Play".
Cheerio,
| Back to top |
Posted: Thu Feb 17, 2005 3:09 pm Post subject: |
No, I transfer the logfiles to my laptop and convert them, then view them using Autoroute. I've never tried playing one on my PPC. _________________ Tim |
| Back to top |
sfi1 Regular Visitor
Joined: 22/05/2003 09:37:02 Posts: 83 Location: United Kingdom
Posted: Sun Feb 20, 2005 1:04 pm Post subject: |
Nice utility and useful too to compare the routings of various software packages - works well with navman .gps files
This thread does remind me of the dissapointment i had with navman's attitude when i questioned them a long while ago about the recording function. It essentially wen't something like this:
Q. I can't seem to get the recording function to play back
A. It's only for sending logs to navman in case of problems
Q Then why does it say you can record and playback routes in the manual
Q If it's only for sending files to navman then why is there a play button
I thought they might at least say the manual's wrong but still doesn't explain why they put in a play button that doesn't do anything. |
| Back to top |
Boxheadc Occasional Visitor
Joined: Feb 21, 2005 Posts: 10 Location: Central Queensland, Australia
Posted: Tue Feb 22, 2005 12:48 pm Post subject: Track Recording |
Mine seems to be saved as a .log file when i view it on my PC, Not a .gps file as LOGCONVERTER wants to see. What do i do to use the file?
Any help appreciated.
Corey |
| Back to top |
Posted: Tue Feb 22, 2005 12:58 pm Post subject: |
If you look in the directory on your PPC where you chose to save the log file, you should have a .gps file too. Try transfer this to your PC via Active Sync. That worked for me. _________________ TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
| Back to top |
Posted: Tue Feb 22, 2005 2:11 pm Post subject: Log File |
HI,
I cannont find a .GPS file anywhere, only the .LOG file. I am a little confused. There have been other posts about using SmartST Desktop but i have not been able to work out how to look at it with that either yet.
Regards
Corey |
| Back to top |
Posted: Tue Feb 22, 2005 2:17 pm Post subject: Re: Log File |
| Boxheadc wrote: | HI,
Regards
Corey |
I'll take a log tonight and let you know more tomorrow...
| Back to top |
Posted: Tue Feb 22, 2005 2:24 pm Post subject: Thankyou |
Thank-you appreciate it,
Also in SmartSt i cannont search for a city, it is greyed out? Any ideas?
Corey |
| Back to top |
Posted: Tue Feb 22, 2005 2:24 pm Post subject: |
Ulf,
The logfile might be saved differently on an iCN. It's also possible that just changing the extension from .log to .gps will do the trick and make the file readable using LogConverter. _________________ Tim |
| Back to top |
| Back to top |
