| Author |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Mon Mar 21, 2005 7:11 pm Post subject: |
Hello Steve
If you go to the https://www.medionshop.co.uk/
Then click PDA/GPS Accessories - GPS Maps, there are maps listed for Spain, for version 3x
| Quote: | Medion Electronics
GPS CD-ROM Map of Spain & Portugal for installed Navigation- Software 3.x
This is a detailed GPS CD-ROM MAP for navigating in Spain & Portugal.
Product No. 40006532 - £69.99 |
If your existing maps are 3x then I would think that they would work, models listed on the web site are:
MD41800, MD41584 and MD41338, if you look on the back of your unit you should see the model no in very small print. |
| Back to top |
Stephenburbidge Occasional Visitor
Posted: Mon Mar 21, 2005 8:04 pm Post subject: Maps |
Thanks for that but I have talked to the people at Medion who tell me that the only maps available for the 150 are the ones that appear when you click on GPS maps - at the moment the only map is USA which I find strange as the UK map must be available as I have it!!
The Model No on my machine is MD95082 which doesn't feature anywhere according to the Medion website and the helpdesk are useless.
The USA map which is suposedly for my model says Navigator vers 4 yet the CD Rom I got with the kit is Medion Navigator 3.1D so I am totally confused - £70 is a lot of money to fork out if the maps does not work!
I just wondered if anyone out there has actually got round the problem and can offer a surefire solution? |
| Back to top |
BigSecret Occasional Visitor
Posted: Mon Mar 21, 2005 10:48 pm Post subject: |
A number of us have been through this kind of thing with Medion before.
The best advice is to keep watching the web site, eventually they will put more maps up when they get them.
They may not have stand alone UK maps as they will have been bundled with the kit you bought. In the past it has been a case of no stock rather than no such product.
Sorry I can't be much more help. |
| Back to top |
Posted: Wed Mar 23, 2005 6:28 pm Post subject: |
| Thanks anyway- I'll keep looking |
| Back to top |
bobgentry Occasional Visitor
Posted: Thu Mar 24, 2005 11:46 am Post subject: |
You can download the 2003 maps from the mio map site http://www.mio-tech.be/downloads/default.asp
for france add
[Region01]
Text="France"
LongText="France,Belgium,Western Switzerland"
MapLang=9
Required=236000
PictureNumber=0
DownTopLeft=257,308
CheckTopLeft=400,320
PointCount=5
Point00=440,291
Point01=384,326
Point02=406,393
Point03=474,395
Point04=483,325
to the MapsUK_Ireland.ini file
found in C:\Program Files\MEDION Navigator 3.1D CE\Installer\Console
and place the dowloded files on a CD in a folder called maps and copy the
disk1.txt file from your original maps CD
you can then load the maps to your medion |
| Back to top |
Posted: Thu Mar 24, 2005 11:48 am Post subject: |
| Most european maps are on this site |
| Back to top |
tel33 Regular Visitor
Joined: Mar 23, 2005 Posts: 159 Location: UK Portsmouth
Posted: Thu Mar 31, 2005 1:59 pm Post subject: |
| Does this mean if you download this map for France (193mb) then it can be used on the Medion MDPNA175 also as its the same as the NDPNA150? |
| Back to top |
Posted: Thu Mar 31, 2005 5:43 pm Post subject: |
Hi there Bob
I tried to do what you said with the files from the site http://www.mio-tech.be/downloads/default.asp which are France, Ibeira, Skandinavia,Deutschland plus Benelux.
I put them all on a cd minus Benelux in a folder called Maps plus I included the file disk1.txt from the pc on its own and not in the folder and when I started the Medion Console it did say France 236mb with a tick in it but would not load, it loaded a preloader onto the disk and nothing more happened.
I realised that this was not the size of the French map and changed the required line in MapsUK_Ireland.ini file the to 239000 to match the France file on the cd, this did not make a difference so I changed it back to 236000
I also noticed that the Text line said "France,Belgium,Western Switzerland" but I thought that would not do anything as it only appears when you pass the mouse over the France entry that is to be loaded from the Medion Console map loading screen.
Is there anything that is wrong with what I have done as it still does not load?
Thanks with anticipation.
tel33 |
| Back to top |
Posted: Thu Mar 31, 2005 5:51 pm Post subject: |
Hi Bob
Just a thought, do you leave the downloaded Maps packed as they come direct from the site when you put them onto CD or do you unpack first them then put them maps in the Maps folder on the CD with the text file?
I have tried the unpacked method which did not work so I will now try the packed method.
tel33 |
| Back to top |
Posted: Mon Apr 04, 2005 9:53 am Post subject: |
You need to unpack the maps and copy the france directory to cddrive:\maps\france.
create a directory called cddrive:\mapdata and place a copy of MAPUK_Ireland.ini in the directory.
it shouls then work ok. |
| Back to top |
Posted: Sat Apr 09, 2005 11:19 pm Post subject: |
| All working fine now, thanks again for your help! :-) |
| Back to top |
murphyjim Occasional Visitor
Posted: Wed Apr 20, 2005 8:03 pm Post subject: |
| Can I get USA maps from the same location ? couldnt see them ? |
| Back to top |
Posted: Thu Apr 21, 2005 7:25 am Post subject: |
| I have not seen any USA maps sadly, I expect that it will be sold on the Medion site eventually when they get their act together! |
| Back to top |
Posted: Tue May 03, 2005 8:16 pm Post subject: Call me thick!!! |
| But I have been told time and time again that only Medion software will operate on the MDPNA150 are you now saying that these maps will now load onto the 150? |
| Back to top |
Posted: Tue May 03, 2005 8:41 pm Post subject: |
Hi there
I can assure you that the maps worked for me ok on a MDPNA175 which is the same as a MDPNA150.
You can only give it a try and see.
tel33 |
| Back to top |
| Back to top |
