Pocket GPS World :: View topic - working! UK Speed Camera's for Medion MDPNA 150
Goto page 1, 2, 3, 4, 5  Next
bobgentry
PostPosted: Thu Mar 10, 2005 3:52 pm    Post subject: working! UK Speed Camera's for Medion MDPNA 150 Reply with quote
I've now got the Speed camera database woking for the MDPNA 150
the files can be downloaded here
http://www.active-soccer.co.uk/The%20Medion%20MDPNA%20150.htm
Meeeeeeee
PostPosted: Mon Mar 14, 2005 10:41 pm    Post subject: Reply with quote
Interesting. How did you convert it?
Unfortunately I can't use the UK database, since I live in Norway, but I'd love to convert the tomtom base.
lancscpl2004
PostPosted: Tue Mar 15, 2005 12:56 am    Post subject: Reply with quote
will this work with the mdpna 100 by any chance?, if not, has anyone else got the camera database for the mdpna 100 as the ones on this site only seem to work with the TTN Navigator
tel33
PostPosted: Wed Mar 23, 2005 6:45 pm    Post subject: Reply with quote
Hi there
I have done all you said to get my PNA175 to show the taskbar and I have downloaded and installed the Camera package, the thing I got stuck on was the HEX Editor, which one did you use?
It would be great if this works :-)
tel33
bobgentry
PostPosted: Thu Mar 24, 2005 11:27 am    Post subject: Reply with quote
You can download a free hex editot from http://www.chmaas.handshake.de/delphi/freeware/xvi32/xvi32.htm#download
back up navigator.exe first and search for the hex string
41 00 75 00 74 00 6F 00 20 00 41 00 6C 00 65 00 72 00 74 00 20 00 31
this represents A u t o A l e r t 1 with each letter followed by a zero.
you can change each character with a new one and save the file.
bobgentry
PostPosted: Thu Mar 24, 2005 11:36 am    Post subject: Reply with quote
The Auto Alert database is very fussy about the csv inport file.
I use Excel to format the csv file creating three columns name,comment,long,lat.
the first field "name" each row must have the same amount of chrs and must not contain ': or '@' symbols.
the second column must have at least six chrs and not contain ':' or '@' chars.
The third and forth columns are the long and lat fields.
after saving the file from excel open it in notepad and remove the last linefeed.
The file should then import OK
tel33
PostPosted: Thu Mar 24, 2005 2:30 pm    Post subject: Reply with quote
Hi there
I think I have doe as you have said I will try it out and let you know. :-)
Thanks for your help.
P.S I notice your site is offline now?
bobgentry
PostPosted: Thu Mar 24, 2005 2:51 pm    Post subject: Reply with quote
oops I'll check the site now
Thanks for the info
tel33
PostPosted: Thu Mar 24, 2005 7:29 pm    Post subject: Reply with quote
Did try it out but got no sound or warning, then I lost the Medion program off both unit and the storage card... got them back thanks to a backup but that scared me a bit!
Will try again, I expect I did it wrong,I got a bit confused managaed to do the Hex EDITING (I THINK!) but could not figure out the last part.
The sounds for the distance alerts are in the lines like change 141;1 to camera and save the camera.wav file to the same directory
::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,141;1,"Poi Alert 1"
Sorry to be a pain but can you explain it to me, I feel a bit thick!
tel33
PostPosted: Thu Mar 24, 2005 9:29 pm    Post subject: Reply with quote
Hi I have been thinking about this, are you saying we have to change the lines to this or is it the one below that?
Correct Number 1?
::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,camera,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,camera,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,camera,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,camera,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,camera,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,camera,"Poi Alert 1"
Correct Number 2?
::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,camera;1,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,camera;1,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,camera;1,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,camera;1,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,camera;1,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,camera;1,"Poi Alert 1"
tel33
PostPosted: Thu Mar 24, 2005 9:44 pm    Post subject: Reply with quote
Ok I think I have got it :-)
Its the Number one thats correct, I have finally figured out that the ; between the "141;1," means the unit will play the "Favourites Alert" e.g. 141; first then it will play the "One" e.g. 1, wav sound after it.
So when its set off as you approach the camera before the change yyou get "Favourites Alert One" coming out in one sentence, clever!
By changing it to just "camera," it plays the "Warning camera ahead" wav instead.
Umm this could get interesting!
Am I right in what I have said?
tel33
frogthedog
PostPosted: Sat Mar 26, 2005 5:13 pm    Post subject: Reply with quote
Hello all.
I am very new to sat nav and have the Medion unit which I rather like. However I would like to have the speed camera positions on my unit.
I have followed your instructions as best I can but cant seem to get it to work. I have downloaded the software to my unit but just cant seem to activate it.
Its almost like I am missing a screen Question
Any help will be greatly recieved
Thanks in advance
Frog
tel33
PostPosted: Tue Mar 29, 2005 9:42 am    Post subject: Reply with quote
Hi there
Iam still working on getting it working too, I have had varying degrees of sucess but will let you know if I get it to work 100% ok.
Regards
tel33
bobgentry
PostPosted: Tue Mar 29, 2005 9:50 am    Post subject: Reply with quote
Hi all
I've been away.
you are right tel33. the data 141;1 can be replaced by up to four words seperated by a ; each word will then play the .wav with the same name so that small sentances may be announced.
bobgentry
PostPosted: Tue Mar 29, 2005 10:39 am    Post subject: Reply with quote
I have placed a zip file on my site with the files needed to display SPEED CAMERA instead of Auto Alert 1
and change the distances to be more practical for camera warnings
The full description is on http://www.active-soccer.co.uk/The%20Medion%20MDPNA%20150.htm
the file can be found here http://www.active-soccer.co.uk/speed%20cameras.zip
Page 1 of 5
24.041 (01 Apr 26)
