Pocket GPS World :: View topic - MMOS2004 + MM Navigator
TC
PostPosted: Sun Apr 03, 2005 9:19 pm    Post subject: MMOS2004 + MM Navigator Reply with quote
In earlier versions of Memory Map, if you had the OS version installed, you could install the Navigator version on the same machine and share the one license. I can't get this going with 4.4.0. Guess they plugged that hole Crying or Very sad or at least the OS told them to plug it?
Anyone know of a work around?
GeoffC
PostPosted: Wed Apr 06, 2005 6:24 am    Post subject: Reply with quote
I don't understand the set up here, what do you mean by the 'Navigator version'?. For the UK there is the PC version 4.4.0 with a corresponding Pocket PC version for PDAs, then there is a version for Europe.
Having installed the UK OS version, what is the second application you are trying to install alongside it?.
Regards
TC
PostPosted: Wed Apr 06, 2005 8:41 pm    Post subject: Memory-Map Navigator Reply with quote
Memory Map Navigator is the product rest of the world uses outside Europe and the UK. I use it because you can load your own maps into it e.g from scanned images. Scanned maps have to be calibrated so that they have real world coordinates based on a mapping projection like UTM. When you buy MM OS calibration is already done, but the ordnance survey have made the authors of MM remove the calibration options as part of the licensing agreement. Try this link.....
http://www.memory-map.com/download_mmnav.htm
MrT
PostPosted: Fri Apr 08, 2005 1:51 pm    Post subject: Reply with quote
Have installed both, they both run independently and use separate installation folders and registry entries and they both use the same registered licence key.
MMOS 4.4.0
MMNAV 4.4.2
23.102 (08 Oct 25)
